Please help 05 x3 Abs sensor problem
Dallasesparza88
This is my first bmw just replaced rear abs sensors, that fixed speedometer and odometer problem but all the lights are still on. What should I try next
getty150
Search here for "battery reset"...sometimes it takes the car some time (several miles of regular drving) to get acclimated to new components...this is what I've experienced anyway.
However, the fault indicator should clear itself...Best to get the scan tool out and run another check...then try to clear via scan tool.
Cheers!
Sent from my SM-A115U using Tapatalk
