Guys I need if someone can help me with something.
My bottom left front spot light (fog) stopped working. It is a aftermarket spot light, so i removed the 2 wires connected to it, the positive and negative and removing H1 globe I see that the globe was blown. Now I got a new one and fitted in the globe and plug in the positive on the globe and then to my shock I see that all of a sudden there is no negative terminal on the housing of spot. There was one there when I initially removed the globe. So I go check the opposite spot and I pulled the wires off and felt that there is a negative terminal on that spot. Im working on this from under the car, I don't want to remove bumper. So Im posting a pic of the above mentioned spot and if someone could assist me as to where I could connect the negative wire to the spot or would I have to replace the whole spot? I hope I don't need to and someone could advice.
