So.....
What a journey it has been so far, I've been keeping Leon super busy (Just a shout out to him & Kieran for all the hard work, I'm not the easiest person to have as a customer :tiptoe
. Seems I should have pulled the full motor plan history before buying the car instead of looking in the service book etc.
I still think the car was a good purchase when I consider what I paid for it, luckily due to this not being my first modded car, I had enough cash buffer for stuff to go wrong along the way.
Have decided that the end goal for this car is a single turbo build in the region of 600whp.
So here's a quick update, not in chronological order:
Front brake pads were finished, installed new ones, rear brake pads have 5k km left on them, then they'll be replaced too.
Previous owner was on clutch number 5 at 88k km, the 5th clutch change is the one that I found documentation of
Seems the flywheel isn't too "lekker" - Will be ordering a Spec Single mass flywheel and stronger clutch to handle the single turbo power when funds are available, it currently holds FBO power fine. The way I see it, I should have done better homework on this, "school fees", but the stock clutch wouldn't have held ST power anyway, so not a huge loss.
Car had 5 or 6 (memory isn't that clear at the moment) oil leaks that needed to be sorted as well as oil that contaminated the coolant. - All oil leaks have been repaired and engine has been flushed, repeatedly, and filled with fresh coolant etc
Car's Guibo and Centre Support Bearing were FINISHED - new Guibo and Centre Support Bearing installed and Propshaft balanced.
Car had a (very bad) patch up job on one of the upper coolant pipes, this started leaking and so on and so forth causing cooling problems - New pipe purchased and installed.
Car's PPK Fan relay packed up, purchased and installed a new one, wasn't happy with the fan speed, Leon and the team opened and modded the old one, much happier with the results.
Right hand engine mount is torn - 2 new mounts already ordered and paid for, including a heat shield for the turbo side mount, thanks Moranor@Axis
We think the turbo's don't have too much life left in them, rattling and don't want to make much more than 18.5 psi, so keeping an eye on those.
Mods carried out:
JB4
DCI's
Downpipes
Secondary CAT's Delete
Charge Pipe
Forge BOV
Big Tom style IC
Metal Boost Pipes
Oil Cooler
Vacuum Lines
Stage 2 Ethanol Compatible LPFP
AEM WMI Kit with progressive controller
So yeah, that's where we're at at the moment, hope I haven't forgotten too much out.
