Paul Cain’s BMW 3002 tti
SL0P0K3 2002ti
The reason why folks like us have to find continued employment as writers and photographers is that people like Paul Cain and his brother Joe must have absorbed all of the available mechanical aptitude from the gene pool! There’s really no other explanation for why this particular 2002 exists and why we’re left snapping away madly while wondering which particular extremity we’d be happiest to part with in order to own it. Seriously, after seeing some of BMW’s recent designs, they could do worse than to employ these two useful gents on their design staff.
“But wait a minute!” you say. It’s only an old 2002. Perhaps it’s restored a little better than the rest, but still, a 2002 nonetheless. And that’s where you’d be wrong. Completely and absolutely one-hundred percent wrong! This particularly-beautiful, immaculately-polished mechanical conveyance has been transformed by the touch of these two brothers into a marvel of modern engineering. This isn’t idle hyperbole either. This is incontrovertible fact as we shall henceforth prove to you Doubting Thomases. You’re as unlikely to find a better 2002 as you would be to put on a dress and try to win the heart of Prince William!
First though, a little background on Paul and Joe. These two enterprising individuals build cars the way Paris Hilton changes her wardrobe; thoroughly, expensively, and creatively. Paul’s prior creations include a 3.8 liter CSi coupe and an M50 single-VANOS 2.5L E21 320i (more impressive due to the modern engine and drive train he used). When pressed for a raison d’etre for this particular 02 project, he replied, “ After the Coupe and the M50 / E21, we wanted to do something very technically-challenging. I’d originally planned to install the all-wheel drive from an E30 3-series iX model.
I wanted to do a one-off ‘modern 2002 Turbo’ with totally updated electronics and controls, and a twin-turbo setup for quicker spooling and better heat dissipation.” Paul eventually dropped the AWD design due to the unwanted weight it would add, the was caused by Joe’s insistence that a correctly engineered 2WD can be quick by being lighter. Joe’s logic won out and it started a major push to “add lightness” to the entire project. By solving the pivotal shift linkage issue Paul decided to create a “transaxle” car instead. Unfortunately, the last BMW built with a transaxle was the famous mid-engine M1. Sourcing an M1 transaxle was out of the question. Keeping the drivetrain all BMW was mandatory.
The attention to detail is amazing.
The answer to the shifer issue and the true beginning of this project was found in the way Getrag bores the shift linkage hole in the E30 M3 “265” transmission housing. Paul was looking at one he’d already purchased when he realized that the shift selector rod hole goes all the way through the casting from front to rear, and is capped with a plug on the bell-housing side. This meant he and Joe could mount the transmission at the rear, run a longer shift rod forward of the transmission, and still retain OEM crisp linkage feel. In fact, the shifter itself would remain in its stock location! That decided, Paul proceeded to purchase a very low-mileage (just 1000 miles on it!) M54 3 liter dual VANOS motor from a 2002 X5 (2002 into a 2002, get it?). He’d already sourced a very clean, Art Simmons-restored late-73 Square Taillight 2002 sedan. These are exempt from the post-1975 emissions laws, making them perfect for engine swaps. Beginning in 2001, he and Joe completely disassembled the car, and started chopping sheet metal with a Sawz-all, removing the firewall, transmission tunnel, most of the trunk, spare tire well and the floor beneath the rear seats.
You can just make out the "twin turbo" embossed into the seat heat rest.
The new M54 engine was set into the bay on custom wood fixture to determine the correct position. Four engine mounts were then fabricated and welded to the subframe and custom cross member. In its final location the block was 9 inches back in the firewall making room for the stock viscous fan and shroud. A custom rear sub-frame was constructed from two OEM ’02 subframes so that the entire assembly could hang from 6 factory rubber mounts. The E39 M5 differential (equipped internally with a Quaiffe torque-sensing unit) was mounted within the sub-frame, then the entire rear suspension was hoisted on a jig, and careful measurements were made above it. At a friend’s sheet metal workshop, Paul used amassed 230 cardboard templates over the 5 years to create the new metal needed to obtain the just-like-the-factory underbody appearance, yet properly hold the new mechanicals in proper alignment. The end result of his work is as amazing as it is thorough. A 37” Chromoly steel rod riding on needle bearings connects the transmission to the shifter with zero play. The fuel tank was cut in half (down to eight U.S. gallons) and moved closer to the rear axle. The spare tire well was eliminated completely. A 1985 528e/ M20 bell-housing (a one-year only part) was sourced to serve as the interface between the clutch and flywheel on the back of the engine and the intermediate shaft which leads to the transmission. A massive double bearing housing was designed and machined to support the driveshaft’s input to the transmission. Aft of the tranny, a small driveshaft was equipped with a rubber guibo before the mounting flange for the differential. Once all of the fabrication and welding was complete, Paul and Joe turned their attention to the engine bay once more.
Paul had chosen the M54 because it weighed in a mere 38 pounds more than the original M10 iron block. If they’d stopped there, it would STILL have been far more powerful than either the original 2002 or 2002 Turbo model. Twin custom-built KKK turbochargers were hung from modified OEM manifolds with a combination of 304 stainless and INCONEL exhaust flanges and bellows. The waste-gate was tied to both halves of the manifold above the valve cover, then shunted into its own mini-muffler and dumped back into the open air just past the turbos under the car. In addition to the two-into-one intercooler used behind the front air dam, an M5 oil cooler was used to shed heat the turbo bearings would be generating. The right front inner wheel arch sheet metal was cut away and reformed to allow room for exhaust tubing to exit the turbos. Eight separate pipes were required for the intercooler tubing. Paul and Joe fabricated a carbon fiber “CSL style” intake plenum then, in a whimsical twist, tagged it in German with a BMW Motorsport replica label which is one digit off from BMW’s own M3 CSL part number! A throttle body was sourced from a BMW M60 3.0 liter V8. 40 lbs/hour Bosch Motorsport injectors and electronic timing are controlled by an Autronic engine management computer. “This system reads all of the OEM Bosch sensors, controls the VANOS, provides electronic boost control and allows infinite control over timing and fuel maps. It is one of the few Non-OEM parts on the car and was the critical breakthrough in tuning and drivablility, It was very gratifying to cut the Siemans ECU module off and walk away from all the OBDII issues” Obviously, you can’t just “chip it” like any other car!
No matter where one looks, amazing details jump out. Custom etching on the passenger’s door mirror reads “Objects in the mirror will disappear quickly”. Four engine mounts were used for the engine/bell-housing combo, and the entire unit sits nine inches farther back than stock. A ZF power rack and pinion from a Porsche 993 was installed in place of the original manual box steering, and requires only 2.1 turns lock to lock. The front hubs were machined from billet aluminum to E12 specs. Coleman 13.2 inch slotted, cross-drilled, cryogenically-treated, and gold irridite-coated rotors were mated to custom-offset hats from Ireland Engineering and paired with Brembo four-piston calipers for the front brakes. The car was recently corner weighted and is within a 30 lbs tolerance at all four corners. Weight distribution with driver is 50.2% Front / 48.8 % Rear. With this step completed, the Eibach springs were swapped for final rate adjustments and the Bilstein sport shocks were returned to Bilstein (San Diego) for custom valving to match the suspension travel and corner weight(s).
Original article: http://classicandvintagebmw.tumblr.com/19743002twinturbo
EDIT BY Nic_s: Added link to original article.
