P0597 OBD error
KarshS
Anyone had this issue?
it says Powertrain: Vehicle speed, idle control and Auxiliary inputs - iso/sae controlled
Thermostat heater control circuit/open
Any advice?
Car is on Motorplan but BMW doesnot pick up this fault on there system. I have used another diagnostic tool to find this error myself.
The problem i am having is were i can feel flat spots on the power and need to switch of the car and start up again for it to be fine....This is intermitant daily.
Any advice?
Pho3niX90
Any advice?
Any advice?
What car is this?
EOBD Code: P0597
Fault Location: Thermostat heater control system - open circuit
Problem cause: Wiring, relay, thermostat heater
mo_s
I would say when its doing it stop at a dealership..don't switch off, leave all switched on with all the error lights etc showing and get someone to help you and check it out then and there.. :thumbs: GL
