confused60
Hi I am new to this so please be patient with me. I have a 1997 BMW E39 540i. It started to over heat was told it was a Radiator problem replaced. Same problem replaced thermostat, Told then cylinder head gasket had the gas test done by Silverton. Found no problem with that. Then replaced water pump still over heating. The thing is that if you drive slowly revs below 1500 does not over heat. If I drive normally over heats (I have not let it over heat past 3/4) If it starts to get hot just slow down and it drops back down to normal. There are no water leaks. The system does build up a lot of pressure. Could the gas reading been a false positive. Any help PLEASE.::blueCry:
