Oil pump sprocket.
///MNM
Hi Guys
The oil-pump sprocket and chain on my E34 M5 somehow came loose. Is it necessary to replace the oil-pump as well?
///MNM
freerider said:
is there any damage to the pump itself?
Hi Freerider
What's up man? I am not sure, still waiting for my mech. to remove and let me know but he said it won't be necessary. I just thought maybe someone on the forum might have had a similar problem in the past?:hammerhead: very frustrating.
Danzellc
My oil pump casing bolts came loose and two bolts were in the oil pan. luckily picked this up on a oil change. I put the bolts back with some thread locker and after 25000 km they are stil tight so ja. The was a common problem with the m60 engine. guess your bolts wer'nt torqued properly on instal.
///MNM
Hi Danzellc
Thanks, the oil pump guide needs to be replaced. Hopefully there isn't anything else broken? I should know by the end of the week. :thumbsup:
