Oil Pump Balancing Shaft vibration
fan01
Hello All,
This is my very first post, so please be patient. I am also not good with cars. I am seeking help with diagnosing vibration which I feel in the cabin and steering wheel of my 2005 BMW 320i E90 N46. I recently had the red oil light come on in the morning when I start up. I took it to a independant mechanic who found that the timing chain guides as well as the oil pump chain guides where broken. He replaced the chains and guides.
He then found out that there was a hole in the oil pump and said it needs to be replaced (+-R13 000.00 from BMW). I didn't have that kind of money and settled for a second hand one which he told me came from a mobile vehicle.
Now the problem (sorry for the long intro). After replacing the original oil pump (which has a balancer shaft), I am feeling vibration when I drive the car. It does not vibrate when idling. I also NEVER had this vibration since owning the car (10years+).
I am having difficulty in trying to get the mechanic to check if he has installed the pump/balancing shaft correctly, as he thinks that something else like the engine mounts is causing the vibration.
I would greatly appreciate it if someone could assist in showing me how to proove that the installation of the oil pump/balance shaft is incorrect. If the installation is correct, then what else could now suddenly cause this annoying vibration, which wasn't there prior to the replacement of the original. Thanks to all.
fan01
Donovan2412 said:
Have you tried balancing the tyres?
Also at what speed is it the worst?
Tyres where rotated and balanced a few months before this repair (I always rotate and balance them at 10 000km). The vibration starts as soon as I start accellarating, even If I rev the engine while stationery at about 2000rpm upwards.
A have another input - the mechanic did not use "bmw special tool" when to align the new (second hand) oil pump - In the bmw workshop manuals I read on-line they mention the use of "bmw special tools" when doing this installation. Thanks for your input, Donovan, anything else comes to your mind?
Nikhil@TheFanatics said:
where about are you based?
I am from Verulam(new Durban), KZN
