Valve cover gasket, oil filter housing gasket, sump gasket, rear seal - main head gasket is a different story though I would think in terms of repair work.
Have you been able to take a look at the car? If there is loads of oil all over the place, best is to try and clean up as best you can, then try and see where the remaining oil is coming out...
