e23 said:
Spiro said:
Mine e46 M, clock on almost 160k, Oil change will be done @ 160, and every 12.5k, using Castrol Edge Sport 10w60, normal retail oil
Spiro how long have you been servicing your ///M with normal Edge Sport? I personally lean towards using Edge Professional (TWS re-branded) but I'd like to hear your comments on how ur car has been running.
The ///M purists suggest that normal Edge Sport is not the same as TWS as the oils have different specs.
Howzit
Yep Correct, TWS and ES are fully different,
i did some random reading before i started using normal Edge Sport, Basically, 3 Years Going Now
TWS is a Long Life Long Dirt Retention Oil, so if you following 25000km intervals and u have an air filter that allows a lot of dirt\dust through then TWS is for you, problem with that is, for a Short Interval a Decent Grade Oil will Do, if you can use an oil like..
Lots of different Opinions..
Liqui Moly
Mobil 1
Royal Purple
Shell Oil
PETRONAS - Syntium
then whats stopping Castrol, which falls onto the recommended list, but Ohhhh noo... it has to be TWS... @ 220 a Bottle
quick Math..
about R1400.00 for 1 oil Service with TWS + Filter
Vs.
2 x 5L Castrol Edge Sport + Oil Filter. @ R800
Then proceed every x amount of KM's 8000km's or so to just buy a new Filter and 1 5L Oil... for the next 4 services... or as you please...
Bull... with a short interval, you don't need a long retention oil, and the way the M Toasts the oil, shorter interval with decent viscosity is good, sometimes the car is not even driven hard, but with the occasional blasting, and still the oil is good for a change...
one of the guys recently brought he's car to me for an oil change, 6 Bottles of "Edge Professional" after peeling the Sticker of, wow "TWS"...
Big Up's for Marketing....
a Bigger Matter of Opinion.... and this is only an opinion after the reading I've did...
:fencelook::fencelook:
