CocoPops
Physical
Length: 174.5 in / 4,432 mm (2.8 in / 72 mm longer than 1 Series Coupe (E82))
Width: 69.8 in / 1,774 mm (1.3 in / 32 mm wider than E82)
Height: 55.8 in / 1,418 mm (0.2 in / 5 mm lower than E82)
Wheelbase: 105.9 in / 2,690 mm (1.3 in / 30 mm longer than E82)
Front Track: 59.9 in / 1,521 mm (1.6 in / 41 mm wider than E82)
Rear Track: 61.3 in / 1,556 mm (1.7 in / 43 mm wider than E82)
Engines
M235i: 3.0L N55 inline 6 cylinder single turbo twin-scroll (2,979cc)
320 hp / 240 kW @ 5800-6000 RPM
330 lb-ft / 450 Nm @ 1400-4500 RPM
0-60 mph: 4.8 sec (auto) / 5.0 sec (manual)
Top speed: 155 mph / 250 kmh
Preliminary EPA Mileage Estimates (MPG) – to be released
228i / 228i xDrive: 2.0L N20 inline 4 cylinder single turbo twin-scroll
240hp @ 5000-6500 RPM
255 lb-ft @ 1450-4800 RPM
0-60 mph: 5.7 sec (auto)
M235i Highlights
8 speed automatic with launch control (standard)
6 speed manual (no-cost option), with dry sump lubrication and short throw shifter
M Sport brakes standard [fixed calipers, four-piston front, two-piston rear, large brake discs]
Adaptive M Suspension with electronically controlled shock absorbers
Individually configured spring and damper system and specific elastokinematics for front suspension
Variable sport steering standard
Standard 18 inch M light alloy wheels with 225/40 and 245/35 tires
Optional 19 inch M Performance wheels
Michelin Pilot Super Sport tires
Specially tuned exhaust
Technologies (some are optional)
Debut of free over-the-air updates to navigation data
Optional for 228i: Adaptive M Suspension (with electronically controlled shock absorbers) (10mm lowering)
Optional for 228i: M Sport Suspension (with extra stiff spring and shock absorbers) (10mm lowering)
Optional for 228i: Variable Sport Steering
Auto Start Stop
Brake Energy Regeneration
ECO PRO, COMFORT, SPORT, SPORT+ selectable driving modes
Electric Power Steering
Optimum Shift Indicator
On-demand operation of ancillary units
Latest iDrive version with touchpad (when navigation equipped)
Latest navigation system
6.5 inch control display
8.8 inch screen for optional Navigation system with Touch Controller
Adaptive Headlights (for bi-xenons)
High Beam Assistant
Active Driving Assistant
Active Cruise Control with Stop & Go function
Lane Departure Warning and Collision Warning systems
Park Distance Control and rear view camera
Parking Assistant
BMW Power.
Engines
M235i Highlights
Auto Start Stop
High Beam Assistant
Parking Assistant
BMW Power.
