Technician
i am in the process of rebuilding my motor for my S50 B30.
E36 M3, 3.0lt
i am finding it increasingly difficult to find the correct pistons and the M3 piston are any where from 16k upwards.
heres the Noob question-
(my knowledge of pistons is very very limited)
i have heard through the grape fine that the 2JZGTE pistons fit (Supra 3lt)
the stock bore is 86mm, stroke 86mm, pin diameter 22mm
i have also read on the net that the opel super boss pistons also fit
the stock bore is 86mm, stoke 86 mm, compression 9.5:1
the stock M3 3.0lt is 86mm bore and 85.8mm stoke.
now i understand that the distance from the pin to the top of the piston needs to be the same, in order to get the clearance and compression ratio the same.
second question, do the 3.2lt pistons fit? (E36 or E46)
the stock bore 86.4mm
will it fit on the same crank and rod?
i am trying my best to get all my info together before i go ahead.
any help or advice will do.
and YES the build thread will be up in time.
E36 M3, 3.0lt
