No low end torque
ChrisBrand
Staff - Legal
Howzit guys,
I noticed with my car its very hard for it to get up to speed the past few weeks.
My initial thoughts are maybe MAF, or camshaft sensor?
At cold idle it also bounces from 500RPM to 1100RPM.
I am also considering doing the VANOS but lets first see what the problem is here.
Any advice will be much appreciated
m0lt3n
A far shot but on my 328i I had issues with my supressors. maybe just check them its easy enough
not sure if its your only problem but do Vanos seals you will not be sorry... ask anyone who has fitted them :)
SPIDER
Had that idle bounce and it turned out to be crank sensor. So check maf and all sensors. Doing vanos always a good thing.
ChrisBrand
Staff - Legal
Im sure vanos seals need replacing. Since ive had the car it hasnt been replaced. So ill be in touch moranor.
Ive had readings before from the cam sensor but the "experts" always brush it off hence why i ask
if you have no codes im pretty sure it will be vanos seals... get the codes read and see what comes up...
S
S1NGH 001
Most probably your VANOS buddy :thumbs:
As Moranor said, you will not be sorry if you do the seals :thumbs:
sclass
Vanos won't cause erratic idle though...but it's the usual suspect for loss of bottom-end laziness.
sclass said:
moranor@axis said:
Vanos can cause idle problems when its very bad...
Wow...! In such cases is it just the seals or does the entire unit need to be refurbished??
normally just the seals but if there is noise then there could be bigger problems...
