I am now a Distributor for NF Octane booster :rollsmile:
benefits are:
Instantly increases octane rating by 3 RON to 10 RON (depending on what boost you choose)
Easy to use 1 bottle per tank
Eliminates detonation / knocking / pinging / pinking
Increases acceleration & performance
Reduces hesitations & engine temperatures
Safe for oxygen sensors & catalytic convertors
Safe for use on direct injection motors
Ideal for valve seat protection
Non-Flammable
this works great on Turbo and tuned cars that need to Eliminate detonation... but untuned NA cars also see an increase in performance to a lesser degree because most cars are designed to operate on 98ron and pull timing to run on less octane depending on conditions...
NF race 6 Ron (black bottle) is the only boost not recommended for use in every tank... it is made for special occasions and will cause problems with use in every tank because of buildup... all the others are designed to be used in every tank and will not cause problems...
if you need 6 Ron on every tank you can use the Ultra Race concentrate on 60l...
using NF Ultra Race concentrate at full 10 Ron mix is also not recommended for every tank but 6 Ron and 8 Ron can be used in every tank...
always use the right octane for your conditions... no point in running 10 Ron all the time if you crawling in traffic just touching the throttle or doing very short trips and hardly heating up the engine... Most of guys that have problems with the high Ron boosts are overdosing for their conditions...
How to find the right octane
benefits are:
Non-Flammable
