nf fuel mix
M135ISPEEDY
Banned
Hi guy's ! i've heard of some guy's using nf , this cant be good for your car , surly you cant use this stuff to often ? any comments :thumbs:
I have plenty customers who use it every tank with 0 problems... use NF products on my car in every tank with noting but good results :)
on boosted cars the Ultra makes a huge difference :rollsmile:
UpNcOmiNg!
Events Organiser
only use NF Ultra.
Not any of the others.
This is a race fuel concentrate. That being said, I don't use it in every tank. I have used it twice in my car, ever.
bottle in 60l is perfect for every tank from a cost vs gain point...
highest you should go is 1 bottle in 20l
the guys that have issues are the ones who over dose thinking it will give them even better performance and then fowl their plugs...
Ultra is the best to use because it has a Very low metal content
long term if you use injector cleaner every 10 tanks it actually keeps you fuel system in better shape
cOlDFuSiOn said:
I want to run additives on my tractor but MP is holding me back so still not too sure..
im not sure they ever test the fuel if they do work on the car :fencelook: but never say never...
M135ISPEEDY said:
do you feel a difference straight away ?
I will let the *35 guys comment on that :)
generally you do feel a difference in smoothness right away but the ECU needs to adjust to take full advantage...
bmsportzn135i
You would need to take it for about a 30km ride for it to mix and run thru the fuel system. From there you will also need to ecu to adapt to it, so red line it from 2nd thru to 4th a few times, you will feel a nice difference from there!
Acheron
If you're tuned the effect is large and definitely noticeable since fuel quality is a big bottleneck for the x35 guys.
I'm not sure how much of a difference you'll notice if stock though.
UpNcOmiNg!
Events Organiser
Your car does run a bit smoother and there is a bit of a power spike when running on a better octane yes. Car does pull harder. If you drive hard for +-10km's it will adapt within that, otherwise 30km's mixed driving sorts it all out!
Bazza
I use NF Street, which is 3 RON in every tank in my 330i. No issues. They do say you can use this in every tank but not the NF Race which is 6 RON. This one apparently blocks up injectors. And the 3 RON definitely makes a difference to me, I mean my car hasn't become a lambo killer but it's smoother and more responsive and I no longer have to listen to motor pinging at low revvs.
bmsportzn135i
What you should look at is the NF race fuel concentrate. You can find out more about the products on www.nitrous.co.za. And for ordering you should speak to Moranor at axis. He will hook you up with good prices!
