Newbie to the forum
JasonR
Hi Guys,
My name is Jason and Im planning on purchasing an e46 330d soon. Ive been browsing the forum for tips/things to look for on these cars. So far Ive figured out that I should stay away from the auto models. However I have seen an E46 2005 330d with 5 speed manual transmission. Now is this the 150Kw or 135kW Version? I have checked on realoem.com and the motor is a M57N.
Help Please!
Jason
Sankekur
Welcome to the forum :wave:
Not that clued up with the diesels, but from what it seems it is best to go for the 6 speed manual ones, and remove the swirl flap as soon as you get the car.
520ebi
JasonR said:
Hi Guys,
Help Please!
Jason
Hi Jason,
Welcome..
2005 330d did not come with 5 speed manual if im not mistaken.. only 6 speed manual..
JasonR
Thanks for the replies guys, well the reason Im interested in this car is because I have a Trade in.
I put in the last 7 digits of the vin no. in realoem and the car comes up as a 2005 model fitted with the M57N - manual transmission, exactly as the dealer advertised. Im just confused as to why its a 5 speed and not 6 speed?
I havent seen the car yet but how would one differentiate between a 150kw model and 135kw model leaving the gearbox out of the equation?
Jason
Bevan
Hi Jason. Welcome. If its a 2005 then it has to be a 150kw version as these were introduced toward the end of 2003, and so was the 6 speed box so I'm not sure why its a 5 speed. Can you post a pic of the engine bay?
Sankekur
moranor@axis said:
maybe the 6 speed gearbox exploded and it was cheaper to put a 5 speed?
A possibility, but that would probably also have required a change of the full clutch and flywheel assembly (if it is anything like the petrol e46 5 and 6 speed) then the prop would also need to be changed as it is shorter for the 6 speed box I think. So it would have made really expensive, probably more so than what a 6 speed box would have cost.
Maybe it just has a 5 speed gearknob on? Crazy I guess but possible :rollsmile:
520ebi
:biglol:
JasonR
Well I havent viewed this car as yet, Im hoping to go see it by the end of the week. The dealer insists its a 5 speed, Ah well I'll just wait and go see it.
A friend of mine told me that if its a 135kw, then it will have a ASC switch and if its 150Kw then it will have a DSC switch - is this correct?
Thanks for the help.
KAKA
The 150kw motors came out in 03, so IMO it's a 150kw. Awesome car, buy it, chip it, beat the I's!! :fencelook:
