New wheels for my 135
Twinz
Forum - Support
Looks good. :thumbs:
Appears that you may experience some rear rubbing...double check it with some heavyweights in the back seats.
Phil_135i
So to answer some of the above.....it rubs ever so slightly with a load in the car. Going to have to take a wheel off to see exactly where its catching, cause its not really visible on the rear tyres thankfully. Hoping that a slight camber adjustment will solve the issue. 1 up in the car and over speed bumps, etc. no rubbing. Just having some BMW badges made up for the wheel centres to finish it off nicely. Certainly transforms the look of the car. Next on the list, piano black roof..........
abmi0000
Negative camber means inner tyre wear, so be careful :thumb:
You must also remember that you camber shifts during hard cornering, so don't just test for rubbing over straight lines.
Phil_135i
abmi0000 said:
Oh, please update this thread if you don't mind :)
http://www.bmwfanatics.co.za/showthread.php?tid=33611
sorted......put the links in there for tyre size and tire offset calculators as well
.....shot for the useful tip. will keep this in mind. If all else fails, bring me the angle grinder....NOT
