New at CrazyDetailer in 2012
BlackFire - Don't just turn heads, create whiplash!
BLACKFIRE Car Care USA is the culmination of more than 30 years of experience in developing premium car products to meet the most stringent standards and expectations. BLACKFIRE Car Care USA products were founded on passion by a perfectionist for perfectionists. Each product is a synergy of cutting edge technologies from Germany, Switzerland, Sweden, and America. For ten years, BLACKFIRE products have upheld the standard that they shouldn't just turn heads... they must CREATE WHIPLASH! [Click here for more info..]
Optimum Polymer Technologies
Optimum car care products are a group of environmentally safe, paint safe, technologically advanced products that will give your vehicle optimum shine and protection.
Optimum Polymer Technologies was founded by an organic chemist whose specialty is polymers and automotive paint formulations. Dr. David Ghodoussi worked backwards from his knowledge of paint's composition to formulate cleaners and protectants best suited for today's finishes. Years of research and testing led to a line of products that deliver superior results without compromising sensitive clear coat finishes or the environment. [Click here for more info...]
AUTOMAGIC Banana Magic (Under R100 Wax Kit)
Under R100 wax
Looking for decent quality wax that looks great and doesn't cost the earth? We think we have the perfect solution for your needs with the Banana Magic combo kit. We've provided the necessary accessories to make the task of applying and removing the wax a breeze. Banana Magic is an easy to work with wax that applies and spreads easily. It buffs off just as effortless without the chalkiness or dust that is common with “budget†waxes. The pleasant banana fragrance makes the waxing experience an enjoyable one. You will not find a better product for under R100 ! [Click Here]
Was :R141.00 Now : R99.00 Save: 30% off
CrazyDetailer - Basic Wash & Wax Kit
Basic washkit
The basic wash & wax kit doesn’t get any simpler than this. Sometimes all you want is just an uncomplicated option to decent car care.
The basic wash and wax kit gives you a good quality shampoo and a straight forward highgloss wax that contains mild cleaners to make it a one step wax. It couldn’t be simpler, wash the car, dry and then apply the PurpleBlaze as thin as possible. Any mild oxidation is removed and once buffed with the towel provided; you will be left with a deep wet shine. PurpleBlaze has a liquid consistency that applies thinly and will flash/cure quick, making it a super quick, super easy product to work with.
[Click Here]
WAS : R177.50 NOW : R150.00 Save: 15% off
CarPro - Iron X Iron Remover 500 ml
Highly effective, acid-free and pH balanced (6~7pH) car paint, wheels & glass cleaner (safe for all wheels including aluminum and alloys).
This formulation is also effective and safe for use on all car surfaces and will not deteriorate clear coats.
Airborne chemical compounds and ferrous particles - particles containing iron - actually penetrate the paint and create corrosive compounds that eat deep into the paint's sub-layers or paint’s pin-holes. This is a gradual process that often is not evident until it's too late. Claying or polishing only removes the particle, not its effects, which are continuing to spread beneath the surface. [Click Here]
CD - Foam Canons *Back in stock*
Turn your pressure washer into a super FOAMER with the CD Foam Cannon !
This foam canon produces clinging foam that you have only ever seen at car washes.
The CD Foam canon out performs the standard soap dispensors that come standard with most pressure washers by a mile!
The CD Foam Cannon sprays the vehicle with a thick coat of soap to loosen and lubricate dirt. On dusty or lightly dirty vehicles, you may not even need to hand-wash. The Foam Cannon HP minimizes the amount of hands-on contact with the vehicle, which can minimize wash-induced swirls. [Click Here]
Under R100 wax
Basic washkit
[Click Here]
