New dyno figures
JadielM
Events Organiser
brent1 said:
Stealth dyno is the happiest dyno in dbn . Autotrix is a better bet
Correction; the happiest Dyno in Durban is the mobile Dyno used at all local shows and events.
Stealth is a preferred Dyno to KZN petrolheads who know what their cars are capable of, but need a base to gauge their own gains, because it's an awesome facility and the customer service is great, not because it inflates their figures and makes up for an inferiority complex.
brent1
Banned
No one really counts the mobile dyno .
But yes you are right about that thing reading very high .
Stealth figures are higher car for car than any other fixed dyno in kzn
JadielM
Events Organiser
Are you referring to stealth Chatsworth?
Kish2604
Administrator
brent1 said:
Kish2604@TheFanatics said:
And we have a new troll on the forum...
How am I trolling?
Nobody said you were trolling but since your happy to carry that label then you shall have it with your 8 posts at this moment in time.
Also if you have a gripe with the different Dynos in Durban then feel free to go start your own thread... This one was about someone's car and HIS Dyno numbers... A Dyno is what it is... It's a tool to measure the power at the wheels or calculated flywheel power, it's worthy to compare if you have multiple cars on the same Dyno at the same day..
Most importantly non of us who have supported stealth or autotrix will argue that there isn't a difference in results, however the difference isn't significant enough to go screaming and shouting that one is more accurate than the other... It must also be understood that autotrix gets hot in there even on a winter evening and that will always give lower or stingier readings...
Ratslaaf
I have to agree with Kish on this one. Just because one Dyno gives the lowest results, doesn't make it the 'truest' Dyno available. Unless the Dyno proudly displays it's load cell calibration certificate, you have no way to determine which one is the most accurate. Then there's other environmental conditions that skews the results as well.
No Dyno will give you an absolute number, it's meant to give you relative performance when compared to other cars under the same environmental conditions.
brent1
Banned
There is a 80 wkw difference from stealth to rallycross on some Gtr's
Yes there is no such thing as an accurate dyno in isolation but most people love stealth as their cars make the most power there.
Stealth figures are higher car for car than any other fixed dyno in kzn.
Some Gtr's make as much as 80 wkw less at rallycross than at stealth .
How am I trolling?
KPM3_30
Moderator
icechilli said:
I'm going to autotrix tonight - any one care to join?
Sent from my SM-G925F using Tapatalk
Might pop by... PM me your number, will text you if I make it
S1NGH 911
brent1 said:
No I am referring to the main stealth hq in enforce park
Just for you brent1
The car ran at Auto-Trix last night.
New mods installed yesterday before the run were:
BP Tyre Pressure
Shield wiper washer fluid
1/2kg salt sprinkled in the boot
Happy now?
Are there any other dyno's you would like to be tested?
brent1
Banned
S1NGH 911 said:
Just for you brent1
BP Tyre Pressure
Happy now?
What does it make at stealth
S1NGH 911
brent1 said:
S1NGH 911 said:
Just for you brent1
BP Tyre Pressure
Happy now?
3wkw more
brent1
Banned
S1NGH 911 said:
Just for you brent1
BP Tyre Pressure
Happy now?
S1NGH 911 said:
brent1 said:
S1NGH 911 said:
Just for you brent1
BP Tyre Pressure
Happy now?
3wkw more
Well that's amazing . Well done .
Why is the torque so low though
922-ZN
brent1 said:
922-ZN said:
brent1 said:
Dude stop trolling, the car makes 400nm ATF stock, so how is 381WNM low???
Is the car stock
yes the car is bone stock standard, nuff said, k thanks bye:hammerhead:
They don't make much modded anyway.
My mazda mps kills them easy
Well done:thumbs:
ZMC
Banned
brent1 said:
922-ZN said:
Is the car stock
Well done. Better than usual I guess, normally mazdas implode.
