CocoPops
Production begins November 2019 for US market.
Debuts at LA Auto Show in November 2019.
2020MY pricing to be announced closer to market launch.
PERFORMANCE / ENGINE / EXHAUST
2.0L turbocharged 4-cylinder
301 HP @ 5000-6250 rpm / 332 lb-ft @ 1750-4500 rpm (M235i xDrive)
0-60 in 4.7 seconds [4.6s with optional M Performance Package's overboots function] (M235i xDrive)
228 HP @ 5000-6000 rpm / 258 lb-ft @ 1450-4500 rpm (228i xDrive)
0-60 in 6.0 seconds (228i xDrive)
155 mph top speed (performance tires) (M235i xDrive)
130 mph top speed (all-season tires) / 151 mph (performance tires) (228i xDrive)
M235i xDrive gets:
larger turbocharger with built-in exhaust manifold and integral diverter valve
reinforced crankshaft with larger diameter main bearings
new pistons
modified connecting rods
larger flow fuel injectors
independent transmission oil cooler (separate from engine's coolant circuit)
electric 850 watt fan
two remote coolant radiators in wheel arches
enlarged expansion tank
dual-branch exhaust system with minimal backpressure
TRANMISSION / PERFORMANCE CONTROL
8 Speed automatic transmission
DSC
DTC setting (Dynamic Traction Control) allows great degree of slip
ARB system (near-actuator wheel slip limitation system)
BMW Performance Control (intelligently applies brakes at wheels on side of the bend)
When DSC switched off, EDLC (Electronic Differential Lock Control) applies brakes to simulate mechanical limited slip differential
xDrive intelligent all-wheel drive system (can split drive 50:50) if necessary
Newly developed standard mechanical Torsen limited- slip differential in M235i xDrive
Launch Control function allows full 332 lb-ft peak torque to be available in first and second gear
CHASSIS / SUSPENSION
Aluminum hood and trunk
Standard bracing in engine compartment and rear suspension area
Strut tower tie bar and bracing on the front axle subframe and in the tunnel area, plus an anti-roll bar mounting with high preload
Standard sports suspension and the M Sport steering with more direct ratio
M Sport suspension standard on M235i xDrive, optional for 228i xDrive as part of M Sport Package
M Sport suspension lowers height by 10mm
Multi-link rear suspension
Optional Dynamic Damper Control (lets driver choose from two different shock settings)
Comfort and Sport settings for Driving Experience Control switch
WHEELS / TIRES / BRAKES
Standard on M235i xDrive: 18-inch M Double spoke wheels with 225/40R18 all-season runflat tires
Standard on 228i xDrive: 17-inch Multi-spoke wheels with 225/45R17 all-season runflat tires.
17-inch wheels with performance non- runflat tires can be specified as can wheel and tire combinations from a varied selection, including 18-inch wheels with 225/40R18 all-season runflat and 19-inch wheels with 235/35R19 performance tires.
Optional M Performance package includes 18-inch wheel with non-runflat performance tires or all season run-flat tires or 19-inch wheels with 235/35R19 non-runflat performance tires or alternatively a 19”-inch bi-color option with performance tires.
M Sport brakes standard on M235i xDrive and optional on 228i xDrive Gran Coupe.
EXTERIOR DESIGN
Frameless doors
Standard full-LED headlights
Four-eyed halo DRL
Full LED, L-shaped rear taillights
Chrome 90mm exhaust tips on 228i xDrive, free-form exhaust design on M235i xDrive set inside a contoured rear diffuser panel
Large optional panoramic roof (29.1-inch by 28.3-inch interior opening) with an interior electric roller blind for shading
Sport line trim standard on 228i xDrive
M Sport Package available for 228i xDrive
M235i xDrive features Cerium Grey finish for the Kidney grille surround and slats, front air inlet surrounds, side sill inserts, mirror caps and free form tailpipe finishers
INTERIOR DESIGN / TECHNOLOGY
Backlit interior trim with six color options -- white, bronze, orange, lilac, green and blue
Standard 8.8-inch center screen with iDrive 6
10.25 inch Control Display iDrive screen (with optional BMW Live Cockpit Professional)
Info Display cluster up to 10.25 inches (with optional BMW Live Cockpit Professional)
iDrive 7 with optional BMW Live Cockpit Professional
Optional 9.25 inch Head-Up Display (HUD)
iDrive Touch Controller (with optional BMW Live Cockpit Professional)
BMW Live Cockpit (standard)
BMW Live Cockpit Professional (optional)
Standard BMW Stereo sound system includes ten speakers and a 205-watt amplifier.
Optional Harman Kardon surround sound system includes 16- speakers and 464 watts amplifier.
12 cubic foot trunk
40/20/40 split rear seats
EXTERIOR COLORS FOR 2020MY
228i xDrive Gran Coupe:
Alpine White
Black Sapphire Metallic
Jet Back
Melbourne Red Metallic
Mineral Grey Metallic
Mineral White Metallic
Seaside Blue Metallic
Storm Bay Metallic
M Sport Package adds:
Misano Blue Metallic
Snapper Rocks Blue Metallic
M235i xDrive:
Alpine White
Storm Bay Metallic
INTERIOR COLORS / TRIMS FOR 2020MY
228i xDrive:
Standard Oyster/Black Sensatec or Black Sensatec
Optional Dakota leather in Magma Red, Mocha, Black with Blue highlights, Oyster or Black
Standard Berlin Illuminated trim
Optional Brooklyn and Boston Illuminated trim
M235i xDrive:
Dakota leather standard
Standard illuminated interior trim Boston
Optional Illuminated Brooklyn Trim and Illuminated Berlin Trim
Ambient lighting available as an option on the 228i xDrive and is standard on the M235i xDrive model.
DRIVER ASSISTANCE SYSTEMS
Standard Frontal Collision Warning with City Collision Mitigation Function
Standard Active Blind Spot Detection
Standard Land Departure Warning system with active lane return
Standard Active Driving Assistant with Lane Change Warning System
Optional Active Cruise Control system with Stop & Go
Standard Park Distance Control (PDC)
Optional Parking Assistance Package
STANDARD AND OPTIONAL EQUIPMENT
Standard for MY2020:
Sport 8-speed automatic transmission
17” Multi-spoke wheels with all-season run-flat tires
Sport leather steering wheel
Alarm System
Rear view camera
LED headlights and fog lamps
Power front Sport seats
40/20/40 Split folding rear seats
Satin Aluminum line exterior trim
Navigation
Illuminated Berlin interior trim (Boston interior trim on M235i xDrive)
Dynamic Cruise Control
iDrive 6
Connected Package Plus
Apple CarPlay Compatibility with 1 year trial
Active Driving Assistant – Lane Departure Warning, Pedestrian Warning with Braking, Frontal Collision Warning with City Collision Mitigation, Blind Spot Detection, Rear Cross Traffic Alert, Rear Collision Preparation, Speed Limit Information.
BMW Assist eCall
BMW Remote Services
Storage Package
The M235i xDrive Gran Coupe model includes the following additional standard equipment:
18-inch M Double-spoke bi-color wheels with all-season run-flat tires?
M Sport Brakes
M Sport Steering wheel
M Sport Steering
M Sport Suspension
Torsen front axle limited slip differential
Aerodynamic Kit
Shadowline exterior trim
Cerium Grey exterior finisher trim color
Ambient lighting
Illuminated Boston interior trim
Comfort Access Keyless entry
Lumbar support
Optional packages include:
Convenience Package (228i xDrive only) – Comfort Access keyless entry, Panoramic moonroof (or moonroof deletion), SiriusXM Satellite Radio with 1 year All-Access Subscription.
M Sport Package (228i xDrive only) – Choice of: 18-inch M Double-spoke bi-color Style 819M wheels with all-season run-flat tires or 18-inch M Y-spoke Style 553M wheels with performance run-flat tires or 18-inch M Forged V-spoke Style 554M wheels with 19-inch M Double-spoke Style 552M wheels with performance non-run- flat tires, M Sport Steering, M Steering Wheel, M Sport Suspension, Aerodynamic Kit, Shadowline Exterior trim (black highgloss design details). The M Sport Package adds additional design features such as kidney struts in aluminum, door sill finishers featuring aluminum inserts with “M” designation, floor mat with “M” lettering, M footrest with metal insert, M pedals stainless steel look, BMW key with “M” lettering and a contrast stitching. The rear spoiler in body color.
Parking Assistance Package – Parking Assistant, Active Park Distance Control, Back- Up Assistant.
Premium Package – Heated Steering Wheel, Universal garage-door opener, Comfort Access keyless entry (std. on M235i xDrive), Panoramic sunroof (or sunroof deletion), Lumbar support (std. on M235i xDrive), Heated front seats, Adaptive Full LED lights, interior Ambient lighting (std. on M235i xDrive), Head-Up display, SiriusXM Satellite Radio with 1 year All-Access Subscription, Connected Package Pro (Remote Services, Concierge Services, Real Time Traffic Information, On-Street Parking Information, In- Car Experiences, Connected Teaser Package with 3 months: Connected Music, Microsoft Office 365), Connected Navigation and Live Cockpit Pro which includes 10.25-inch digital instrument display and the BMW Intelligent Personal Assistant.
Dynamic Handling Package (228i xDrive only) – choice of 18-inch Y-Spoke bi-color Style 553M wheels with run-flat tires, 19-inch M Double-spoke bi-color Style 552M wheels with performance non-runflat tires, Dynamic Damper Control, M Sport Brakes, extended Shadowline exterior trim which adds high gloss black kidney frame and struts, tailpipe finishers and bumper details.
Shadow Line Package (M235i xDrive only) – Choice of: 18-inch Forged V-Spoke Style 554M wheels with all-season run-flat tires or 18-inch M bi-color Style 553 wheels with performance runflat tires or 18-inch M V-spoke Style 554M wheels with performance non-runflat tires or 19-inch M Double-spoke bi-color wheels with performance runflat tires, Dynamic Damper Control, Black Mirror caps, Extended Shadowline trim, M Performance Package (turbo overboost function).
Stand-alone options on the 2 Series Gran Coupe include:
Remote Engine Start
17-inch Double-spoke bi-color Style 548 wheels with all-season runflat tires (228i
xDrive only)
17-inch Double-spoke bi-color Style 549 wheels with all-season runflat tires (228i xDrive only)
17-inch Double-spoke bi-color Style 549 wheels with performance non-runflat tires (228i xDrive only)
18-inch Multi-spoke bi-color Style 488 wheels with all-season runflat tires (228i xDrive only)
18-inch M V-spoke Style 554M wheels with all-season runflat tires (M235i xDrive only)
18-inch M V-spoke Style 554M wheels with performance non-runflat tires (M235i
xDrive only)
19-inch M Double-spoke bi-color Style 552M wheels with performance tires (M235i
xDrive only)
19-inch M Forged V-Spoke Style 557M wheels with performance non-runflat tires
Mobility Kit
Space-saver spare tire (228i xDrive only)
Panoramic moonroof
Illuminated Brooklyn interior trim (M235i xDrive only)
Illuminated Boston interior trim (228i xDrive only)
Ambient interior lighting (std. on M235i xDrive)
M Sport seats for driver and front passenger (M235i xDrive only)
Extended Shadowline Trim (M235i xDrive only)
Harman-Kardon Surround Sound system
Wireless mobile device charging
Live Cockpit Pro – 10.25 inch digital and 10.25 center displays, Connected Navigation,
Gesture Control
Heated Front Seats and Steering Wheel
Mirror Caps in Black (228i xDrive only)
BMW Power.
M235i xDrive gets:
new pistons
DSC
EXTERIOR DESIGN
Frameless doors
Four-eyed halo DRL
12 cubic foot trunk
Alpine White
Jet Back
Storm Bay Metallic
M235i xDrive:
Alpine White
Storm Bay Metallic
228i xDrive:
M235i xDrive:
Alarm System
Rear view camera
Navigation
iDrive 6
BMW Assist eCall
BMW Remote Services
Storage Package
M Sport Brakes
M Sport Steering
M Sport Suspension
Aerodynamic Kit
Ambient lighting
Lumbar support
Remote Engine Start
xDrive only)
xDrive only)
xDrive only)
Mobility Kit
Panoramic moonroof
Gesture Control
BMW Power.
