CocoPops
Availability / Production
Coupe production begins July 2013
Convertible production begins November 2013
Coupe arrives in showrooms August-September, convertible arrives in showrooms December-January
Powertrains / Models (U.S.)
428i
2.0L turbo inline 4 cylinder (N20)
240 hp @ 5000 RPM / 255 lb-ft torque @ 1250-4800 RPM
0-60 mph: 5.7 sec
435i
3.0L TwinPower (twin-scroll) Turbo inline 6 cylinder (N55)
300 hp @ 5800 RPM / 300 lb-ft torque @ 1200-5000 RPM
0-60 mph: 5.3 sec
Physicals / Curb Weight / Construction
Length: 182.6 in / 4,638 mm (1 inch longer than E92 Coupe)
Width: 71.9 in / 1,825 mm (1.7 inches wider than E92 Coupe)
Height: 53.6 in / 1,362 mm (0.6 inches lower than E92 Coupe)
Wheelbase: 110.6 in / 2,810 mm (2 inches longer than E92 Coupe)
Front track: 110.6 in / 1,545 mm (1.8 inches wider than E92 Coupe)
Rear track: 62.7 in / 1,593 mm (3.1 inches wider than E92 Coupe)
Weight: Between 44 pounds (20kg) and 99 pounds (45kg) lighter than predecessor E92, depending on engine and equipment
Cd (drag coefficient): 0.28 (same as current E92 M3 Coupe)
Center of gravity: below 20 inches (500mm) - lowest CoG of any BMW currently available
50:50 weight distribution
Exterior / Lines / M Sport
M Sport
M Sport suspension standard (RWD models only)
M Sport Brakes standard (also available as stand-alone option on all 435i coupes and optional upgrade on 428i coupe when M Sport is chosen)
M aerodynamic package (front apron, rear bumper/diffuser, side skirts)
High-gloss Shadow Line trim
Estoril Blue Metallic option only available with M Sport
M Sport 18" or optional 19" wheels (435i only)
Interior: M door sills, M leather steering wheel, M driver's footrest
Sport Line
High-gloss black B-pillars and window trim
Nine molded high-gloss black kidney grille slats in chrome colored surround
Three black air intakes in front apron
Black Air Breathers
18 inch or optional 19 inch wheels (435i only)
Black trim strip level with rear apron
Black exhaust tips
Interior: black and red accents (such as red trim rings in instrument dial and red stitching on sport steering wheel), anthracite headliner, available Coral Red interior includes Coral Red leather sport seats, red door panel trim, red lower section for instrument panel
Luxury Line
Eleven chrome kidney grille slats with matte black sides
Two high-gloss double bridges in front apron's outer air intakes
Chrome Air Breathers
Chrome window trim
18 inch or option 19 inch wheels (435i only)
Chrome strip in rear apron
Chrome exhaust tips
Interior: Chrome surround for audio and air conditioning system, high-gloss wood strips, leather seats w/ stitching and choice of two upholstery variants in four colors
Interior / Interior Packages
Transmission / Steering / Efficientdynamics
8 speed autoamtic
6 speed manual
Electric power Servotronic steering system (speed-sensitive power assistance)
Optional Variable Sport Steering (part of Dynamic Handling Package) with quicker on-center steering ratio with better turn-in during cornering
Chassis / Suspension / Brakes / Wheels
Springs and dampening, axle kinematics and elastokinematics tailored for 4 Series (although chassis construction based on F30 3 Series)
Modifications to camber angle, the track and the roll center (0.7 inch lower than 3 Series Sedan)
Particular attention paid to strengthening front section of the car
Additional strut between front axle subframe and body sill
Lightweight aluminum torque struts, wishbones, swivel bearings
BMw Power.
