Barkie
My wife's 320i e46 have this clutch noise that sounds like a rattle underneath the car. If you hold the car on it's clutch against an incline, all seems to be fine. As soon as you start letting the clutch out to start moving, you can hear this rattle sound under the car and feel a slight shudder. This only happens when you use low RPM. Also you only have this while you are busy slipping the clutch.If you use 1200 RPM and higher, everything is normal.
