N55 stock power
i8am3
Made 236kw@APR dyno day with my stock n55 135...strongest stock 135 there...stock n54 335 made 217kw on the same day...done on pump fuel...Impressed with power seeing that people say that the n54 makes more power than n55...the guys @ APR say that 135s make around 225kw there...
Twinz
Forum - Support
Nice figure there. :thumbsup: Who said the N54 made more power stock?
Nothing is a given or predetermined on a dyno.
Are you planning any power mods for the car?
///M335
thats good power for stock but how did you manage 11kws more, than the stock flywheel figure given from the factory??
nomercy
Welldone, that's some good power there bud! Very impressive for stock, I did 201kw at snails stock so your car must go very well!!
HardM3
Nice :thumbsup: I think people mean that the N54 reacts much more effectively to tuning than the N55. I've also come across this info on 1addicts as well. Can any users substantiate this?
A
anile8-zn
volumetric efficiency on the n55 is lower than that of a boosted n54.
mahinder-suresh
1M:thinking:
Oh and by the way van der Linde's dyno runs very accurate and is 20wkw less(yes 20 less) than 2 other dyno's i tested my M on so i could believe the difference as the tollerances BMW manufacture under are very precise. Good power there buddy!
A
anile8-zn
2 turbos in this case can move more air as the boost pressure is raised towards the rev limit .
being able to keep up with the airflow needs of the engine as the revs climb is key to the "efficiency"
