Liam H
Hi everyone. My 2012 F30 335i N55 pwg has started developing a chirping/squealing noise almost identical to the sound i had when i had a bad pulley. I replaced the tensioner, idler pulley belt about 3 weeks go. The noise has returned, but i have absolutely no leaks infront of the engine and the belt is fine. NOTE: This noise ONLY appears when I've driven a while and the engine is hot (oil temp at 105-110°C. I performed the test where i remove the oil cap to see if the noise continues, as soon as I remove the oil cap, the noise dissappears. Is this then confirmed its my pcv or valve cover? There isn't any oil leaks around the valve cover either, and no DME error codes at all which is strange to me. Ive scanned multiple times for codes for vacuum leaks, but nothing.
The car is currently on stage 1 MHD, with upgraded charge pipe and catless downpipe. I've hear that tuned N55s go through PCV and valve covers quite quick, my valve cover is about 3 years old i think.
Any help or tips would be appreciated.
