Hi fellow fanatics,
My JB4 causes some clicking in the throttle body during idle. After complaining about this to the manufacturers I eventually ended up buying a new board. Connected this last night, an the problem remains.:smashScreen: If the JB4 is removed - no clicking what so ever.
The car throws no codes and auto delete is off.
I took the car for a drive with the new board and I was getting boost up to 15psi on map 4:RedNo: On map one probably 17psi.
I stopped driving her hard as I don't want to damage anything.
Next thing the water pump switches on while the car is off. This ran for a good couple of minutes until I inserted they key. I don't have OCC, so should not be getting the common water pump fault others experience. so now I'm absolutely confused.....and hating JB4.
I know that only logs will sort out the boost issue, but has anybody experience with-
1. the throttle clicking/ ticking &
2. the water pump switching on.
FYI. My car has new coils, injectors, water pump, HPFP and spark plugs so very much doubt its a fueling or timing issue.
Please help:blueCry:
