N54 waterpump and thermostat
individj
which warranty company..i don't have a warranty and was looking at R100 000 for my cars issue..you cannot own a modern car without a warranty unfortunately
NBN
Iceman12596 said:
Glad i took the aftermarket warranty, they covered my Voltage Regualtor and Alternator Refurb and now my snails :)
May i ask who you are with, and if you had to remove your mods when you did your warranty claims?
NBN
@Iceman12596 , May i ask who you are with, and if you had to remove your mods when you did your warranty claims?
Mia225
ended up getting my parts from Beras in alberton. they were the cheapest and the pump is also the latest revised continental part
all in R6750 for the pump and t-stat. fitment will take place this week
Soprano890925
Will you be fitting it yourself?
Mia225
i will be mad to do it myself... lol.
SubLoaded
Resident Derailer
Nice bud, good to know that this is the lowest price that I've heard for these parts. Makes me feel a little better lol
Danny2
Not that bad a job.
Doing one tonight
If you want I can assist with this.
cRed001
Is it better to replace your waterpump and thermostat once you're in the region of 130,000km's or just wait for it fail and then replace?
SubLoaded
Resident Derailer
Well - its a common item. Unless you want to be stranded on the road then I'd say change it. I'm just over 140k and seems to be fine. No errors on the scanner either.
I don't have high hopes for the part though. It's a case of "when" and not "if" it breaks
cRed001
Thats my feeling as well. Im not keen on being on stranded and risking overheating issues. Now I need to get my mind around forking out +/- R10k for something that is'nt broken.
Mia225
so just a bit of an update... ended up going DIY. was actually pretty simple. not even half a day job and it was done.
sadly though, after replacing waterpump and t-stat, i still had coolant level low warning. did some investigation and found that my sensor on the bottom of the expansion tank was faulty. got a new one from goldwagen @ R67. 10mins to replace and all is now well. which leads me to believe that my sensor was probably the initial cause of the overheat warning as the old pump is functioning still.
did a lookup and the pump was replaced under warranty recall @92k :(
non the less, at least now i know its something to now worry about for some time:eek:mgwaiting:
SubLoaded
Resident Derailer
:hammerhead: :hammerhead:
Iceman12596
Good going buds.
Better safe then sorry i always say :)
BeemerFanatic
Events Organiser
Iceman12596 said:
PM Sent
@ Iceman, please send me this info also?
