hoosain
Chedds said:Hi guys
I have 135i N54 1month out of warranty 80k km and as soon as I chipped ECU engine quit at high revs/ wide throttle, engine then sounded like it was running on 3cyl. Switching on and off back to normal.
Dealer said it was coil packs but when I got the two that were replaced there was no obvious sign of deterioration rubber looks ok. Only the two plugs looked fouled, some whitish powder/deposit around the body. R900 ea later methinks I was had. Said I should replace other 4? How do I check that the coil packs are actually the issue? All spark plugs changed. Total bill R5k.
what software(chip) are you running?
