N54 Coil Packs
hoosain
Chedds said:
Hi guys
I have 135i N54 1month out of warranty 80k km and as soon as I chipped ECU engine quit at high revs/ wide throttle, engine then sounded like it was running on 3cyl. Switching on and off back to normal.
Dealer said it was coil packs but when I got the two that were replaced there was no obvious sign of deterioration rubber looks ok. Only the two plugs looked fouled, some whitish powder/deposit around the body. R900 ea later methinks I was had. Said I should replace other 4? How do I check that the coil packs are actually the issue? All spark plugs changed. Total bill R5k.
what software(chip) are you running?
Chavoos
hoosain said:
Chedds said:
Hi guys
Important question . See what my experience was on this thread : http://www.bmwfanatics.co.za/showthread.php?tid=52051&page=2
Chedds
Issue with misfire already present with OEM software, it was exacerbated with ATM chip. Even with replaced 2 coils, still some misfire under hard acc. http://www.bmwfanatics.co.za/images/smilies/2014/blueCry.gif
hoosain said:
Chedds said:
Hi guys
Kotters
HI Guys, my apologies for not checking this thread more often.
My contact at Bosch has fallen Ill and been booked off for a couple of months.
I cannot get coils for the time being.
Your best bet is Diesel Electric if you need urgently.
