KrS24 said:Mods besides the turbo, Big cooler, Cone intake. Single DP. Stock exhaust. CP and BOV. No meth.
Not to sure about NF, I always had better results with Eth. I may try out BP 98 and see what that does for the car.
KrS24 said:Hit a little stumbling block this weekend.
I changed the wastegate spring to a much stiffer spring and the car started to go beyond the boost target. Swapped out for another medium strength spring. While fitting the wastegate on I dropped the banjo bolt in the engine bay.:hammerhead:
After an hour of searching I gave up.(serves me right for working at 10pm on Valentines day)
The car is on the lift now and we will continue tuning this week.
The numbers where looking good before it failed safe into map 4.
Just under 500whp and 700nm
