it all comes down to the torque vectoring surrounding the prop shaft when the water pump starts pumping due to the external temp sensor triggering the activation of the sun visors, and thus making the wheel bearings convert the motion into kinetic energy that can only be countered with pulling strenuously on the window washer stick allowing the pressure build up in the airbag sensor to escape creating a vacuum in the abs unit and that will let the oil pump filter the dirt out of the air intake keeping the chain clear of the piston action :mmm:
