My New Ride e92 335i
KarshS
Boosted@TheFanatics said:
Google the Golf T Mod, removing the plug will throw a soft code and bmw can pick it up when the car goes in for services etc
Nothing a faulty plug cant fix :roflol:
KarshS
Thanks to Fa'ees from XclusivModz for getting me my JB4. Awesome service as always with such a quick turnaround time. :ty:
Neesh AKA 4piper thanks for helping me fit the JB this weekend. Really appreciate it. :blowheart:
Rowen, Shicks, Rosh for all the stupid questions and always being there to help me. You guys rock :clapper::clapper::praise::praise:
Now to sort out some small issues to get the car running perfectly.
R!Yo
Staff - Social Media
Coming together nicely bru!!!
Someone change this man's forum name to Karsh335i :roflol::roflol:
KarshS
cant change that name.... the addiction started in a 330d :rollsmile:
KarshS
Not much has changed.
Been really having issues with the JB4 and 30ff codes
From start to now this is what has been done:
Injectors was replaced.
Oil service
Fuel filter
Spark Plugs
Noticed the vacuum lines was in a bad state at a few points. Got them changed
had the latest firmware done on the car
Oil leak from the head. That was repaired.
Installed a charge pipe
Had all the vacuum lines checked
Car is at BMW again and they just told me they replacing coil packs.
The car will not boost over 10 psi when the jb4 is installed. Wastegate adaptions are set to 70 and goes up to 150 on the first run.
Only codes been thrown is 30ff boost below target.
Same issues with stock or aftermarket CP.
Checked all pipes and they are secure.
The battle continues :hammerhead:
#n54 life
Latest log attached
  • 2016-05-05 11_51_21.csv
hoosain
your logs seem fine i cant understand why the car is throwing 30ff codes
my suggestion is to reset adaptations and load a pump back end flash and see what happens
BeamerMan
Make sure with the new firmware that your adaptions and read those specific notes as well....
I am sure I read somewhere about the 30ff. Just cannot find it now.
Kish2604
Administrator
Karsh... Drop me a call when you can.. Let see if we can troubleshoot for you... That is a very weird log to review..
Sent on the move from my S7edge
