Sabretooth tiger
///Shaun said:Dippies said:caddy can you explain the circumstances that led up to the initial fail
:fencelook:
WATER PUMP FAILURE has no signs/telltales if its going to fail.
If just bascially comes up with the warning light , car goes into limp and thats it , you left on the side of the road.
Thats one thing i will openly admit is where BMW stuffed up IMO , there is no water temp indication or oil temp indications on the lower models of the E90 , on the 335 for example there is a oil temp indication but no water temps.
All i can suggest is to make sure one has roadside assitance or bmw on call.
have they atleast corrected that on the F30?
