This system can easily be amplified to improve the quality of sound and allow these speakers to play to their abilities. MTX Matching 4 channel amplifier also available at R2,599.
Installation services also available at an additional cost as well as all required accessories such as wiring kits, hi-low convertors with remote out etc
Specifications :
•RMS Power : 150W
•Max Power : 450W
•Impedance : 4Ω
•Frequency response : 23Hz - 25kHz
•Sensitivity : 93,5 dB/2,83v/1m
•Tweeter diameter : 25mm (1'')
•Midrange diameter : 10cm (4")
•Woofer diameter : 20cm (8")
•Compatible with BMW : E60 E61 E70 E71 E81 E82 E83 E84 E87 E88 E90 E91 E92 E93 F10 F11 F12 F13 F20 F21 F25 F30 F31 F35
•Compatible with Mini : R55 R56 R57 R58 R59, only fits midranges and tweeters not the 8” woofers.
•Compatible with Mini : R60 R61, complete 3-way system
Features :
•Original MTX OEM replacement set, fits without modifications, the car stays original
•Works with the original car radio
•Upgradable with RT30.4M or RT50.4M to absolute high-end hifi sound system
•Midranges and woofers with fiberglass cones and black rubber surrounds
•Powerfull Neodimium Magnets
•25mm softdome tweeter
•Inline crossovers with original BMW connections
•Cables and screws included
•Great power handling
•High Sound Quality
Description :
Designed to upgrade the original BMW & Mini sound system to an absolute high-end sound system without any modifications, sawing or drilling. The step by step process in the manual makes it even easier to install the system.
