Mo's E39 530i Individual
KPM3_30
Moderator
Excellent work, the tablet install is brilliant! When are you going to offer this as a service..? :tiptoe:
Zound
Great install! The line noise that you are hearing could be the USB charging circuit. Try unplug the USB charger and see if it removes the problem.
msm
Yep - without the USB charger plugged in, there is no noise.
FiRi@Rennzport
Absolutely brilliant. Well done Brother [PERSON RAISING BOTH HANDS IN CELEBRATION]
Sent from my VIE-L29 using Tapatalk
Gizmo
Banned
msm
Small update on the car:
A bit of preventative maintenance first: Giubo was replaced, courtesy of Gizmo, with the OEM part:
And then another forum member (Sash) was kind enough to flog his old, rusty wheels - just kidding - a rather decent set of original 6 series 19" wheels.
Driveway is slightly sloped, so the rear is a bit raised in the pics - however, it sits almost flush with the front height when level.
Ride quality is surprising comfortable - slightly harsher than the 17s, but certainly acceptable. I did go with a marginally higher profile tyre size though with the aim of retaining some comfort. The original 17s will remain in storage should I change my mind...
Bmw.wp
WOW....:blowheart:
Your cars colour is beautiful :praise:
