Meth problems
Hi Guy's Help
I seem to have a problem with my meth set up , firstly my FSB was faulty so replaced the FSB unit and loaded the latest firmware no meth flow on oil gauge , if i put my ignition on and select menu 7/5 and test , pump comes on , meth flow on gauge works, meth flow is fine before nozzle ,Meth safety = 0 / Meth Trigger=1 /Meth flow scaling=60 / Meth Additive=40 and Meth starts at 7.5 PSI , is there anything else i should check. :cry:
Twinz
Forum - Support
Hard to help without logs.
Log it then i can assist to fix the problem.
