Chavoos said:You guys should make about 330-350wkw .
Meth is necessary and preferably a bigger cooler.
LPFP upgrade for higher Eth .
We made about 300wkw on stock snails.
All the best with the tuning
M@rk said:Chavoos said:You guys should make about 330-350wkw .
All depending on the boost and dyno .
M@rk said:No new updates as yet , bought an jb4 ,went from MHD to Jb4/bef and bought a meth kit now to install and get it dallied in i have seen 22 psi on them thus far with out eth just pump .:smilebounce:
Iceman12596 said:Forgot about this thread, if i can add to share knowledge Mine are done and running the 3.5 Bar map sensor, no complaints and car is running well.
akash said:M@rk said:No new updates as yet , bought an jb4 ,went from MHD to Jb4/bef and bought a meth kit now to install and get it dallied in i have seen 22 psi on them thus far with out eth just pump .:smilebounce:
Did you install a 3.5bar Tmap sensor?
akash said:Iceman12596 said:Forgot about this thread, if i can add to share knowledge Mine are done and running the 3.5 Bar map sensor, no complaints and car is running well.
Did you dyno yet?
Hows the responsiveness compared to stock snails?
Iceman12596 said:akash said:Iceman12596 said:Forgot about this thread, if i can add to share knowledge Mine are done and running the 3.5 Bar map sensor, no complaints and car is running well.
Did you dyno yet?
Didn't Dyno yet bud.
Compared to stock snails i find them to be awake and ready when you drop the hammer, but then again, i am running JB4 with BEF so that will make a difference.
Also revs ALOT quicker and smoother, Car is an animal on map 6 though, i also find myself spinning in 2nd gear LOL
Maby @M@rk can give his thought's and feeback here as well ?
tc335tt said:Hi guys, I'm making around 325wkws ,meth and 20% eth, MHD 2+
bmw335ie90 said:Yae those v10s or any na m car has weak torque.
I think so to. How much faster does it feel on 18psi vs the v10?
