CocoPops
Powertrain
Shares 4.4L M TwinPower Turbo V8 (S63Tü) engine from the M5 and M6
560 horsepower (peak at 5,750 – 7,000 rpm)
500 lb-ft torque (peak from 1,500rpm – 5,750rpm)
7200 RPM redline
0-60mph in 4.1 seconds
155mph top speed (electronically limited)
S63Tü engine runs compression ratio of 10:1
Double VANOS and Valvetronic technology
Brake Energy Regeneration and the Auto Start-Stop function
Transmission
7 speed M-Double Clutch Transmission (M-DCT) with Drivelogic (shared with the M5 and M6 Coupe)
D1, D2, and D3 automatic shift program and S1, S2, and S3 manual shift programs
Active M Differential
Chassis / Suspension / Brakes / Wheels
Aluminum intensive integral rear axle subframe in the M6 Gran Coupe bolted to body to maximize body rigidity and handling precision
Reinforced chassis mountings at the front and rear axles to ensure dynamic forces are passed through to the body structure
M Dynamic Damper Control (DDC) electronically controlled shock absorbers
Comfort, Sport and Sport Plus modes
Dynamic Stability Control (DSC) and Anti-lock Braking System (ABS) that includes Cornering Brake Control (CBC), Dynamic Brake Control (DBC), Brake Assistant, Brake Fade Compensation function, a Brake Drying function and Start-off Assistant
Brake rotors is 15.7 inches (400 mm) at the front and 15.6 inches (396 mm) at the rear
Six piston calipers front
Optional M Carbon Ceramic brakes (available with Spring 2013 production), in gold color
Ceramic brakes measure 16.1 inches (410 mm) in diameter at the front and 15.6 inches (396 mm) at the rear
Ceramic brakes are 42.8 lb (19.4 kg) lighter than the standard brakes
Ceramic brakes are six-piston fixed radial calipers at the front, with single-piston floating calipers at the rear
20 inch
// M Power.
