M3 weights
922-ZN
Sup guys,
Post your weights, I've read about and the general consensus is around 1650kg for the E92, mine is 1535kg tho:bin:
922-ZN
Spiro said:
is yours..
1535 before the driver? and 1650 with the driver ?
:sorry:
Mine is 1535 as per scale weight with just under half tank fuel and no driver. The general dry weights from bimmerpost etc are around 1650kg dry weight I think
@ Kish, disc weight is fine, I'm sure it will be close enough. What's the weight on your car?
Andy1GP
1535kg for an E90? That's the same as the E46M3. I remember 4pipers car being 1530 on the Zwartkops scales.
I figured the E90's were about a 100kg's heavier than the E46M3's.
922-ZN
I thought so also, and it's not like my car lacks equipment, the only extras I don't have is HK Sound and elec folding mirrors
200ts
Scales may differ depending on calibration, @922-ZN that sounds quite light for an E92 M3 unless you have removed seats, battery etc. best to compare with another M3 on the same scale, same fuel etc.
