M3 e90 drive train noise please help!
Revs
Hi,
This has happened on my M. I have found a link on you tube that is extally the same. Please advise on what the problem is.
Tks
200ts
Stones behind brake dust covers, need to listen properly but I have the same on both my V8's
AdiS
Revs said:
Hi,
Tks
How have you concluded that the prop needs replacing? A clunk like that could easily be serviceable parts like the flex disc and Centre supporting bearing, or rear CV.
If its only a clunk, and not causing an actual vibration under load or at high speed, then I would think that there is a good chance it can be fixed.
