M3 "E46" Vanos
Touring GP
Hi Guys,
Apparently my Vanos on my car needs to be replaced .
Any idea where can i find a used good condition one ..
Can the Vanos be repaired ?:argh::argh:
calypso
Send your old one to DrVanos.com and get a refirb unit.
If you pay a deposit fee they will send one down before you have to send yours, so you dont have to be without car for long periods of time.
Their service is great, also they somewhat modded for better reliability.
What exactly happened to yours? Maybe the repair is easier then you think.
AdiS
Yea it really depends on where the failure is in the vanos. If you head on over to m3 forum . net there is a huge amount of information about the different VANOS failures and how to fix them.
The common failure areas of e46 M3 Vanos are as follows:
VANOS sealing plate
Problem: VANOS sealing plate comes with o-rings rated for 212º. Sometimes it gets hotter than 212º in there.
Solution: Beisan systems VANOS sealing plate. Come with o-rings rated for 400º. http://www.beisansystems.com/procedu..._procedure.htm
Price: ~$40 for part (final price TBD, being release november 2011)
Labor: 1-2 hours
DIY difficulty: 5
VANOS solenoid failure
Problem: cracked solder joints in the solenoid coil pack resulting from cold solder joint, heat cycling, and mechanical movement
Solution: Beisan systems rebuilt VANOS solenoid pack-- OEM with extra strength added. (or DrVanos)
Price: $300 (after core return)
Labor: 1-2 hours
DIY difficulty: 5
VANOS bolt failure, which can lead to engine failure
Problem: intake cam sprocket bolts back out over time and eventually sheer.
Solution: Z4 M S54s use an updated bolt design that is make of harder steel. Combine with loctite.
Price: $5 for parts
Labor: 5-8 hours
DIY difficulty: 7
VANOS exhaust cam sprocket tab failure
Problem: tabs that connect the cams to the sprockets break off over time
Solution: Dr. VANOS replacement. Cryogenically frozen for extra hardness and larger tabs to take the slack out of the system (reduce stress).
Price: $800 for part
Labor: 6-9 hours
DIY difficulty: 8
Dealer's only ever quote on entire VANOS replacement which is very expensive, so rather find out exactly what part of the VANOS has failed and fix that part only as above.
