M3 CSL windsceen washer bottle
splintheter
My windscreen washer bottle has a crack in it, do you gusy know if its the same as the standard M3's bottle and if it is an easy DIY to replace it.
Thanks,
Anthony
calypso
CSL only according to RealOEM. Just make sure that maybe the hose is disconnected. Good luck getting to it.
kabal
early morning edit to remove info about expansion bottle and NOT windshield washer bottle :)
MikeBMW
The windscreen washer bottle sits behind the front right of the bumper. Need to probably remove the bumper to get to it.
msm
On a "regular" M3, you can get to the washer bottle by removing the front right tyre, then the fender liner on the front bumper side. Not sure if the CSL is the same.
BTW, mine was leaking when I got it - turned out to be the washer where the pump fits - was full of muck and not sitting properly - cleaned it, reseated and it was fine.
