m3 brake light circut failure
ivan2terrible
Got this warning on my ///m and thought it was loose bulb or something. Only 2 find no brake lights @ all. Tried cleaning the fittings nothing. Sprayed fuses wit penetrant, nothing. Then decided 2 check switch on pedal which i couldn't remove, apparently a bia....h 2 remove. So still not sure wats goin on. But on the plug that fits behind the switch, i bridge 2 wires and bam, brakes work. Now is it really the switch that cost almost 400 @ the stealers? Any ideas
Peejay
Events Organiser
Its the switch. I think you need 2 push down on the pedal to remove it. But you must just check sometimes when the switch becomes faulty it works in oppersite, while the pedal is out your lights come on and when you press the lights go off.
Smok breakfast run on the 12th?
smok
thanks heven, im good 2 go for the breakfast run... hopefully it will be better than the last 1...
ivan2terrible
Thx. Not sure if i'll b around that time. Busy time, eskom got lots of power stations off. If i'm not busy, i'm def in
Peejay
Events Organiser
Ok guys if you coming for the run I think you need to add your names to the list in that thread. Just check under the Natal forum
