BillyBob said:As much as i agree with the keep it OEM statement, Dependent on what the car gets used for, aftermarket poly-urethane bushes might suit your purposes better if you're a very enthusiastic type of driver who likes getting it sideways often.
Same goes for pulleys - the stock water pump pulley is plastic, wich can get brittle with time.. A few specialist online companies have alloy underdrive pulley kits available, that effectively free up a few more horsepower by reducing parasitic drag losses. These will also last forever and a day if you get a proper set.
BMC and K&N also make replacement drop-in air filters for the stock airbox, which will last you forever with regular cleaning, frees up a tiny bit of horsepower, and won't gunk up your MAF provided you're conservative with filter oil application.
Pirate items are a no-no - use original belts, oil and service items as far as possible and stay away from your local spares shop when it comes to your M3... But bear in mind that the aftermarket scene caters for some awesome goodies for the M3's, which would actually make more power / last longer than the equivalent OEM BMW bits.
Agreed +100000 :thumbs:
