m135i overheating
Taran Rodrigues
hey everyone
i have a m135i 2012 65XXXkm
this past week my car overheated and i phoned bmw on call and they took my car to alberante in alberton,went to fetch my car today after saying they couldnt find a problem
and on the way home it overheated again so bmw is on the way to collect my car
so was just wondering if this has happened to anyone else.. and if anyone may know what the problem is?
MikeR
mmmm can I be the first to ask what mods have been done on the car. ?
I hope its minor like a thermostat not opening.
Taran Rodrigues
jb4 and exhaust.
i removed everything before it went to bmw
Mpcheshire said:
Had same issue was intermittent water pump.
apparently they checked the water pump and they say it was working fine
MikeR
jb4 and exhaust.
what I mean is any mods can add fuel to the fire by adding the extra stress to the motor, that could be the underlying problem.
as precaution get them to swap out the thermostat - they will pick up if the water pump is faulty when doing so.
if its only intermittent its a warning to get it sorted now.
Lizzard
this sounds like the waterpump to me. Had same issue on my 330i, on my way home to pretoria one day coming back from a friend in krugersdorp my car suddenly made a noise, looked at my navigation screen and there was this slow down car overheating thing. Pulled of the road, trying to slow down my heart for second so I could think clearly and tried starting it up again, car started right up no problem. 4 months later same thing happened, same road also. And then more frequent to every week and eventually the car's fan will go ballistic on startup like I was a boeing getting ready for lift off .....
Talking about it, did you hear the electric fan go boeing fast when this happened? This is a tell tale sign that the waterpump is on its way out
Taran Rodrigues
Iceman12596 said:
Get a second opinion, take it to another bmw dealership
well if they cant find anything again then i will
jb4 and exhaust.
yup i can understand that maybe the mods cause cause the problem, but doesnt help if they cant find anything wrong with the car
thanks okay will ask them to check the thermostat, and check the water pump
cOlDFuSiOn
Which warning comes up? Surely that should help them?
My 335i was running hot in traffic, basically the radiator fan was on constantly.. Car had a software update and Ll was good. The late F20 'overheated' as it had a sensor issue..
Good luck getting it sorted.
Acheron
This. Some cars require a new radiator fan/control unit as well.
The waterpump/thermostat issue is common on the E-series cars and the above on F-series N55's.
Quick///M
Mine use to go into limp mode where power would be cut off but turns out it was a faulty thermostat, JSN sorted it out for me
Taran Rodrigues
thats what happened to me, thanks will ask them to check it out for me
zaleonardz
Maybe not the same problem, but I recently had issues on my moms N20
It would overheat, intermittently.
Took it to BMW they diagnosed waterpump and thermostat, car was then fine for a few months.
Then it started again, they diagnosed water pump once more, and it was swapped out under warrantee.
They then said it is still doing it, and gave me a quote to replace the fan and a bunch of stuff, nearly 40k
told them to go get lost, and I eventually found the issue as a broken wire to the water pump, it was intermittently losing power.
Replaced the wire, car has not said boo since..
