M135i 0 - 100 times - Logged with Torque Pro
Quick///M
MaX said:
Yeah, chirp on gear change. I've seen wheelspin in 5th in sport+
Speaking of tires.... hows yours looking? I dont think mine's going to give me 5000km....:hammerhead:
Mine are still in good nick, car is on 18 000km. I did have a nasty screw in the rear tire 3 weeks ago luckily it was fixed with a plug hope it holds out. How much milage have you done on your days so far ?
MaX
Well mine was a factory demo, got it with 12 000km on the clock and they looked brand new then. We then took the car on a epic road trip pushing the Km's to 15500. Since then, last 3 months, i've only done 1 000km and since then I must admit the tires arent looking too good. Guess because I only drive the car on the weekend, when I drive it, I only want to drive it like its supposed to be driven.
Johann83
Hi guys.
Used Torque Pro for some logging.
Power on wheels
214 kW 392 Nm
Intake temp
45 deg
Boost
0.7 bar
Launch Control (auto)
0-100 kph 5.2s
400 m 13.3s
No Launch (manual)
0-100 kph 4.7s
400 m 12.8s
2013 BMW M135i Auto EWG
I am sending the vehicle in next week for:
ECU Flash
JB4
BMS intake
Downpipe
Charge pipe
Will do some logging again after that.
My previous logs the car was stock standard only mixing OB1 5lt on 30lt 95.
M3_devil
Gents I stand under correction but if you running JB4 with CAN integration using OBD plug harness and you plug anything into OBD port on car then the JB4 reverts back to MAP 1 with no CAN integration.
