Lowering Options for the F30
Nish_H
So, I have done a search but have not had much luck, hence posting the question.
Apologies if it has been discussed in the past
With the Eibach or HnR option, is motorplan affected? And if so, is it the "entire" motorplan or only claims that are suspension related.
Or are am I forced to fork out R10k for the Schnitzer springs with a minimal drop of around 15mm
Are there any other options?
DieselFan
Yes motorplan is effected. Some say it will only be for suspension but is that really worth loosing?
Contact moranor on the forum. The ACS shouldn't be 10k
Nish_H
Yeah, not a big fan of compressing springs
Schnitzer springs fitted is 10.5k.
Looks like that may be the option that I will go for
M135i
Been through this.
Looks like ACS is the only way to go.
And yes it's R10.5k fitted for 15mm
Hnr I think are the nicest drop at 35mm but will void the MP
Dean ///M
Limited Profile
Just spray the springs Plastidip black. They won't notice anything. I have a set of H&R taken off a F30.
Jeremy
Ballie. Don't do anything that will drop plan. Rather spend that extra or remove the springs whenever it's going in.
Nish_H
moranor@axis said:
pop me your vin ACS springs are normally around 5k... i will get you a proper price :)
Thanks bud, I think you did give me a quote already on email:thumbs:
Just waiting to confirm price of fitting with BMW
M135i
Fitting costs about R4800. Springs R4900 about. Then add Vat.
I'll double check the quote I got. This was from JSN
Sent from my  iPhone
