Loss of Water
Pozessed TS
Howzat guys,
I need some advice please, a few weeks back my car started loosing water….every second day the water light would come onn and I needed to fill her up (+/- a litre a time) only to find the radiator cap seals where shot. I replaced that, no sign of water leaking but I still have to fill her up every second day. I spoke to a guy yesterday and he said that I need to bleed it because of the air bubbles? Is there any test I can do to find out why shes loosing water like this?
Shes a E46,325 I
Pozessed TS
I stay in Melville and work in Bryanston
moranor@axis said:
go to silverton radiators and get them to do a pressure test...
Cool thanks, will do. Will that test be able to pick up the leak?
did not see Gizmos post
on second thoughts if you can get the car to Gizmo it will be your best bet :)
pressure test will show where its leaking... Gizmo will know the common places for it to leak (might even have the equipment to do the pressure test) and your car is safe with him he does not take shortcuts...
Pozessed TS
Thanks guys for the replies, I just got back from Silverton Radiators and they did a pressure test...the radiator is actually leaking :nonono:
