Looking after a cold engine
Law
I always drive conservatively when the engine is cold and would like your input on what the acceptable/correct revs vs. throttle input is in reference to the oil temperature. The oil temperature gauge settles about 1mm before 120 degrees celcius after driving on an open road for some time, so I know this is the optimal temperate but what about whilst she is still getting there?
msm
Small thread derail: Does the F30 335i have both an oil temp and water temp gauge?
vylint
I'm keen to know this too. But I don't know how to see the temp other then the air temp. :flyfun:
Law
It only has an oil temperature gauge. The major markers are at 70, 90, 120, 140 and 170 degrees celsius with small indicator lines inbetween, each representing 4 degrees celsius.
P
petrivanzyl
On the diesel it settles about 1mm before 100 degrees C after a few minutes...
CamZo
Well I read somewhere that optimal temperature from cold for most engines is when it is higher then 60degrees for the engine oil.... Will try and find the article for the facts.
rick540
Start idle for 20 secs and drive off normally as you would. just dont nail it till the oil temp is past 80 ceclius.
The thin oils they are using these days do their job from cold.
J
Jakkals_F30
I normally drive very relaxed and keep the revs to max 2000 till i get onto the highway.. that is about 4km then for another 4km odd up to 3000rpm and from there it's normal driving.
I have always believed you don't drive a car hard until its warmed up properly cause you might end up damaging something. Rick540 makes a good point with the thinner oils and i would like to see what they say is the best to do nowadays.
Nice topic though LAW :thumbs:
Bayn46
I don't like to sit in the driveway and let the car idle, you are only warming up the engine that way. Taking a calm drive, below 3k rpm, for the first few kms is how I do it. That way, everything warms up together.
Sent from my HTC One X using Tapatalk 2
D
Dippies
And what if your car does not have Oil temp Gauge ? Anyone now how to check on E90?
Nastaliq
This is correct. I spoke to a BMW tech some time ago about warming up the diesel engine from cold start. He mentioned, that in the old way, the right thing to do was let a diesel engine idle for a few minutes before driving off cautiously, while the car got up to operating temperature.
Newer cars and better design means that idling it, just warms up certain components. The ideal way is to drive your car slowly without over-revving it for a few kms, while the block, diff and everthing else warms up as well as the oil.
Cooling off period on the diesel turbo or other turbo'd car seems to be the topic of much speculation.
Also, be mindful that for those who drive their cars for very short distances every day, the cars oil almost never gets up to operating temperature. The risk is developing sludge from the oil, which basically ceases the pistons up and you get ZERO acceleration. I had this problem on my previous E90, where my return distance each day was 8kms.
After 6 months of this, the engine developed sludge and had to go into the dealership.
The engine was taken apart, stripped of all the sludge, and reassembled.
The E90 and E90 LCI do not have an oil temp gauge. You can check from a secret menu each time, but this cant be easily done on the fly all the time either.
You can find out how to do it here:
http://www.bmwfanatics.co.za/showthread.php?tid=9294&pid=91700&highlight=hidden+menu#pid91700
vylint
I'm with Dippies on this one, I am also wondering how to tell oil temp.
:flyfun:
Nastaliq
:flyfun:
THen click the link above your post..............:fishwack:
rick540
When I finally got a car with an oil temparature guage I was surprised at how much longer oil takes to warm up compared to the coolant.
I would say 10 - 15 minutes from the time the temp guages hits normal, only then is the oil at around 70-80 celcius - longer than one would think.
