were you at full throttle?
if yes the values indicate otherwise
the car is pulling back quite a bit of timing a backend flash might help here
all other parameters seem fine
Also...the correct manner in which to run logs is from 2500rpm till at least 6200rpm in 3rd and 4th gear. Minimum the whole of third. This will give all the info required and paint a better picture.
