KL 15 & KL 30
3Thirsty
Hi,
I have a E92 320i, I am currently trying to do a software update but it does not see KL15 or KL30 in ISTA/D or ISTA/P.
Is this perhaps a configuration error or version error?
ISTA/D - 3.52
ISTA/p - 3.57
Thanks,
Lizzard
Got this info of another site for you, will not post the link mhhauto but the info
Quote
Hi mate,
Easy way to check if it's hardware or software. Connect the ICOM to another PC via LAN. While plugged into the OBD port of the car. Connect a charger to prevent battery drain. Access the ICOM manager in internet explorer (requires adobe flash) by typing the ip address (http://169.254.x.x:60080) use ITool radar to obtain the I.P address of the ICOM. ICOM clones usually http://169.254.92.38:60080 willl work. You will be presented with a screen to enter a user name and password.
Username is root
Password is NZY1150263
Once in the main screen select Channel/Device Configuration
You will see KL15 and KL30 voltage. Both should read battery voltage. If not and this problem happens on all cars newer than 2008 than problem is the ICOM controller not switching. If both show battery voltage the more likely software related. You can try to restore the ICOM by following my thread listed below or can send it in for repairs or buy a new one
Hope this helped.
End quote
You might need to send Gert a pm to see if he can help you.
